URL Parameter to filter or search by field with domain
425
09-02-2025 05:02 AM
Status: Open
Labels (3)
JamesTurner2
I have an inspection workflow that uses Field Maps, Survey123, and a custom Microsoft Power App. The Power App acts as a workflow tracker where field workers manage their inspections. I would like the power app to serve as the launching point for the inspection so that users can go to an inspection in the app and then click a URL to launch Field Maps zoomed or filtered to the relevant features.
So I need to create a URL with parameters that opens a map in Field Maps with two layers filtered. The field that the filter applies to is domain restricted. It doesn't seem like this is currently supported based on the URL parameters documentation. An acceptable workaround would be to open the map zoomed to a single polygon, however, the field that I need to search on has a domain to restrict entries, and it doesn't seem like you can configure a layer search on a field with domains.
