Oriented Imagery functionality in Field Maps
519
10-02-2025 02:03 AM
DavidlMason
Field Maps should be able to capture Oriented Imagery the same way QuickCapture does. I like the simplicity of QuickCapture, but our users like to also look at a map to see where they are and find specific areas that we should in the map used in Field Maps.
Our only option now is users switch between both apps so they can both see the map and take pictures, which isn't so ideal. I've seen some work arounds, but they require post-processing and lots more set up.
1 Comment
DougMorgenthaler
