Layers Group Filter in Field Maps
4688
10
03-23-2024 02:54 PM
KaramKhattabBMCD
Let me start that I really appreciate the new filter option in FieldMaps Designer. But it would amazing if multiple layers can be group filtered based on a common attribute/value. Just like the group filter in WAB and EXP. @JeffShaner 🙂
10 Comments
JeffShaner
Hey @KaramKhattabBMCD thank you for the post and the mention.
Can you provide more details on the use case for group filters?
KaramKhattabBMCD
Thank you so much @JeffShaner for your quick response !! I appreciate it.
During fielding, we have 10-15 layers that have an attribute of CircuitID,  our field crew have to go to each layer and filter based on that Circuit ID, to only see the assets that have been collected for that circuit. this helps them visually and organize their efforts per circuit.
The current filter option is doing the job right now. But it would be way more efficient and easier for the user to simply filter all of these layers based on that common attribute to create that quick dynamic view of that circuit assets.
I know that someone might say, well create separate maps and put a CircuitID filter within the web-map to customize the view . We thought about that but you can just think about the effort of trying to maintain/ manage 10-15 maps per fielding effort and if a change happens to one, we need to do it 15 times.
Thank you and for the Field Maps team !
JeffShaner
Thank you for the use case @KaramKhattabBMCD
I can see the value in this, especially for utilities. There are similar requests asking for filtering of group layers in ArcGIS Online and ArcGIS Pro:
Would it be fair to assume you'd like this capability across our web and desktop apps as well?
HollyTorpey_LSA
Being able to filter all layers in a group within Field Maps would be useful for us as well. We often have web maps with several data collection template layers (e.g. general points, general lines, general polygons, JD points, JD lines, JD polygons, rare plant points, rare plant polygons, etc.) that all ave a ProjectID field, and sometimes projects overlap spatially.
I suggested a similar idea at the Developer Summit for the Attachment Viewer Instant App, where we display attachments from all these template layers and users often need to filter multiple layers to see only the features from the project they're interested in. I can also see this being a time saver in Pro.
KaramKhattabBMCD
@JeffShaner Thank you again for your response !
Yes I do think it is fair to assume that this is a functionality that needs to be across the products. Layers almost always need to be grouped and displayed by a clause. In Exp and WAB this was solved using their Group Filter widgets. I think it would be nice to have that live at the WEB MAP  level to cascade across.
@HollyTorpey_LSA  Thank you for your input ! I do agree that it would be really useful inside the Attachment viewer !
Scott_Sambell
I kudos this (although for some reason that is disabled on this idea).
Our case is that we usually always have the main point layer and a view of it to symbolise by two different expressions using several attributes. One expression defines the colour and shape of the point, and another expression defines the colour and shape of the "halo" around it.  We need to use a view because we are always offline enabled in everything we do
We could combine the expressions but
  1. It would often create 100+ different symbols
  2. There is no symbol in AGOL ootb that does what we need.
  3. It would be a nightmare to maintain when one of the domains change which happens fairly often
Not sure if i explained that properly, but happy to jump on a call to explain.  We basically use this in all of our projects so i've got at least 50 examples i could show you.
Cheers.
JB_SEPA
Hi all,
I would just like to add my support @JeffShaner for further filter functionality similar to that seen in dashboards, WAB, and ExpB that triggers from a feature selection. My colleagues are responsible for inspecting farm compliance across Scotland for the the Scottish Government and the Field Map app does not allow this to happen and I need to "declutter" the map using a filter that triggers when we select a farm pin. The map contains many lines, points and polygons all related to the farm pin and we are desperately in need of functionality to screen out the neighbouring farms and their features to focus only on the farm of interest. Dashboards and ExpB does it beautifully.
I see it as critical functionality for anyone carrying out inspection based work.
Do you have this in the roadmap at all??
Thanks, Jonathan
MeleKoneya
I just ran in to the need to be able to filter two layers.
I found this thread and was wondering if there has been any updates on its progress.
We have two layers in the map where our Fire Department must select their station and shift and filter the layers.    I would be nice from a user standpoint if they only had to filter once.
Thank you for any updates on this,
Mele
bswes
@JeffShaner Hoping this useful idea is getting traction.
An even more basic use case example is a point dataset derived from a polygon dataset. In Field Maps (and Pro), we have grouped the layers together. The point dataset is displayed for small scale map views, but then switches to the polygon dataset at larger map scales. When the user wants to filter this pair of datasets in Field Maps, they have to set the same filter on both layers, even though the attribute tables are identical. In our particular use case, we have 6-7 groups of pairs of datasets, and all 12-14 datasets have identical attribute table schemas.
Being able to set the filter at the group level makes intuitive sense for the user and would be a massive time saver.
LaurentSavoy1
@JeffShaner
I was wondering if Esri plans to roll out a date range filter in production, similar to what QFIELD offers.
My team works rotating shifts from 6:00–18:00 and 18:00–06:00.
Our operators need to quickly view the data collected during the previous shift (and sometimes a bit earlier as well).
Unfortunately, I currently need to rely on another application to work efficiently. Without this update, I can’t really use Field Maps for our workflow.
Please keep me posted if this feature is planned—it would completely change my workflow and make things much easier for all of our users.
