Field Maps offline basemap toggle
1509
04-03-2024 09:47 AM
Status: Open
MichaelMoore_ODFW
Thank you for providing a forum for soliciting constructive ideas.
I work for the Oregon Dept. of Fish and Wildlife.  we use FieldMaps primarily in the course of our work duties.
We often are working in remote areas where we use offline downloaded areas for data collection needs.
in collector classic, there was an option to download different basemaps which we found very helpful depending on the task, and needs in the field.
My question and/or request is there an option in FieldMaps to change basemaps offline, and if not, could this please be considered as you move forward in future software developments.
[email protected]
thank you!
-Mike
2 Comments
AbiDhakal
Yes, in Collector we are able to side load tpk or tpkx for Offline use while also having the option to use Esri's default basemap. Now, with Field Maps it is either or. You either use the side loaded basemap for Offline use, or you go Online. But, if you have to use Esri's basemap to go Offline you have to disable taking 'Tile package offline and enable 'Basemap defined by the web map' from the Field Maps Designer page. Field Maps needs to have the option to go Offline with tpk/tpkx or the Esri basemap without having to reconfigure the thing from the Field Maps Designer page. The reconfiguring takes away one for the other. It is a lousy workflow. This is what Esri does. It gives you to begin with and it takes it away from you.
Thank you,
Abi
Brian_Bishop
I also have this request from my users, we work almost exclusively offline and different field workers have different preferences; also many find that they need different basemaps in different areas. Currently, no matter how we provide the basemaps for offline areas, everyone using the same map has to get the same basemap when they  take their map offline, even though I have the map set up to allow users to choose a different basemap when they are working online. This should be an option that can be configured when taking a map offline as well.
