Field Maps form field display
213
04-28-2026 02:39 AM
Status: Open
Labels (2)
KatieQuantrell
When setting up the field maps form using field maps designer, depending on the field type the fields appearance varies making the forms look inconsistent/mismatched.
Labels appear in a different places in relation to the field. Ie for drop down fields the label is by default shown above the field, whereas for free text or number fields the label appears within the field itself. This makes the form look inconsistent when viewed, making it harder to navigate. A work around is to put placeholders for any fields where the label would be in the field. To force the label to be above instead. But feel it would be better to just have this as the default.
For calculated fields these again look different, with no field outlines being shown, just text on the form background, which again makes the overall look of the forms inconsistent (ie this is different to how defaulted filed appear).
It would be great to improve the look of the form to make it more consistent and improved user experience.
