Add Datum Transformation
370
05-18-2026 04:34 AM
TaraRussell-Weir
We are trying to use a GPS receiver for Field Maps to collect data.  Currently our data along with the County's data is in NAD 1983 StatePlane Michigan South FIPS 2113 (Intl Feet), in order for us to use a GPS to collect data, I need to be able to transform the data which we are Collecting on the MDOT CORS which is GCS NAD 1983 2011 I need to be able to transform it back to what my GIS data is in.  By not having this the new data that I would collect using any GPS receiver is essentially shifted 2.5' SE.
Please add a Datum Transformation of WGS_1984_(ITRF00)_To_NAD_1983 (Area of Use: USA – CONUS and Alaska; PRVI)
The combination I need is
  • Set GNSS Coordinate System: Choose GCS NAD 1983 2011 (WKID 6318)
  • Set Map Coordinate System: Choose WGS 1984 Web Mercator Auxiliary Sphere (WKID: 3857)
  • Set Datum Transformation: Select WGS_1984_(ITRF00)_To_NAD_1983 (Area of Use: USA – CONUS and Alaska; PRVI).
1 Comment
fjramos
Have you attempted to use the transformation option: ~WGS_1984_(ITRF08)_To_NAD_1983_2011 + WGS_1984_(ITRF00)_To_NAD_1983 USA - CONUS and Alaska; PRVI + USA - CONUS and Alaska; PRVI
