Viewing table in web map on mobile device
2510
05-03-2017 05:04 PM
PatrickGrady
I would like to know the best way to view the attribute table for a feature within a web map on a mobile? I of course know how to click/ID a single feature and see it's attributes pop up, but how can I view/scroll through an entire table? Is this possible with the Explorer app? Are there other apps that I can achieve this with? Essentially, I would like to be able to view a table in a similar way to how I can view a spreadsheet with the Google Sheets app.
DerekLaw
Esri Esteemed Contributor
Hi Patrick,
> I would like to ... view the attribute table for a feature within a web map on a mobile? ... Are there other apps that I can achieve this with? ...
You could use Web AppBuilder for ArcGIS. You can quickly and easily create a new web app with it, based on a web map and display the attribute tables of its data layers using the Attribute Table widget. Web AppBuilder runs in a web browser on mobile devices.
Hope this helps,
PatrickGrady
Thanks Derek, this is helpful. However, some of my users will be using this in the field without connectivity, hence why I was hoping that there is a way to achieve this with an app such as Explorer or Collector. Is there an option like this available to me?
DerekLaw
Hi Patrick,
Unfortunately, I don't believe you can view a layer's 'entire' attribute table in either Explorer for ArcGIS or Collector for ArcGIS. You can view a feature's attributes with a pop-up in these apps, but not the 'entire' attribute table. If these solution apps don't meet your needs, I suppose you could develop your own custom app with one of the ArcGIS Runtime SDKs.
Hope this helps,
