Dear friends. I created an mmpk file with a raster dataset and feature class in ARCGIS Pro. After that I copied the same mmpk file to \ Android \ data \ com.esri.explorer \ files \ mappackages folder on the device. When I open the same in the explorer for arcgis vector data is loaded but the raters do not appear even though it is in the layers. Please Help.
Its your projection. I changed it to Web Mercator and the image then loads with the data.
Thanks ! I will try
Sent from Yahoo Mail on Android
On pet, maj 15, 2020 at 11:18, Mervyn Lotter<[email protected]> wrote:
#yiv9567181834 * #yiv9567181834 a #yiv9567181834 body {font-family:Helvetica, Arial, sans-serif;}#yiv9567181834 #yiv9567181834 h1, #yiv9567181834 h2, #yiv9567181834 h3, #yiv9567181834 h4, #yiv9567181834 h5, #yiv9567181834 h6, #yiv9567181834 p, #yiv9567181834 hr {}#yiv9567181834 .yiv9567181834button td {}
GeoNet, The Esri Community | GIS and Geospatial Professional Community |
Re: raters do not appear even though it is in the layers
reply from Mervyn Lotter in Explorer for ArcGIS - View the full discussion
Reply to this message by replying to this email, or go to the message on GeoNet, The Esri Community | GIS and Geospatial Professional Community |
Start a new discussion in Explorer for ArcGIS by email or at GeoNet, The Esri Community | GIS and Geospatial Professional Community |
Following Re: raters do not appear even though it is in the layers in these streams: Inbox |
This email was sent by GeoNet, The Esri Community | GIS and Geospatial Professional Community because you are a registered user.
You may unsubscribe instantly from GeoNet, The Esri Community | GIS and Geospatial Professional Community, or adjust email frequency in your email preferences
Thank you so much for help! I loaded the file and the raster is finally visible.
