raters do not appear even though it is in the layers
768
05-15-2020 01:25 AM
damirblagojevic
Dear friends. I created an mmpk file with a raster dataset and feature class in ARCGIS Pro. After that I copied the same mmpk file to \ Android \ data \ com.esri.explorer \ files \ mappackages folder on the device. When I open the same in the explorer for arcgis vector data is loaded but the raters do not appear even though it is in the layers. Please Help.
MervynLotter
MVP Regular Contributor
Its your projection. I changed it to Web Mercator and the image then loads with the data.
damirblagojevic
Thanks ! I will try
Sent from Yahoo Mail on Android
On pet, maj 15, 2020 at 11:18, Mervyn Lotter<geonet@esri.com> wrote:
#yiv9567181834 * #yiv9567181834 a #yiv9567181834 body {font-family:Helvetica, Arial, sans-serif;}#yiv9567181834 #yiv9567181834 h1, #yiv9567181834 h2, #yiv9567181834 h3, #yiv9567181834 h4, #yiv9567181834 h5, #yiv9567181834 h6, #yiv9567181834 p, #yiv9567181834 hr {}#yiv9567181834 .yiv9567181834button td {}
GeoNet, The Esri Community
GIS and Geospatial Professional Community
Re: raters do not appear even though it is in the layers
reply from Mervyn Lotter in Explorer for ArcGIS - View the full discussion
Reply to this message by replying to this email, or go to the message on GeoNet, The Esri Community
Start a new discussion in Explorer for ArcGIS by email or at GeoNet, The Esri Community
Following Re: raters do not appear even though it is in the layers in these streams: Inbox
This email was sent by GeoNet, The Esri Community | GIS and Geospatial Professional Community because you are a registered user.
You may unsubscribe instantly from GeoNet, The Esri Community | GIS and Geospatial Professional Community, or adjust email frequency in your email preferences
damirblagojevic
Thank you so much for help! I loaded the file and the raster is finally visible.
