Popups not displayed in Explorer for iOS (iPhone)
4715
12-04-2015 10:30 AM
JadeFreeman
I'm trying to configure popups on a dynamic map service layer.  While the popups display and work just fine in my web map in Portal, they will not display when I load the map in Explorer for iOS on my iPhone.
The layer is a dynamic map service with several sublayers and I'm configuring popups on several of the sublayers.  I have several other maps where this is working just fine with other map services so I'm guessing it must be something unique to this particular map service but I have no idea of how to figure out what it is.
The service is secured (token) or I would share the url.
Is there any options that needs to be enabled in ArcGIS Server?
Tags (3)
Saranya-Kesavan_esri
Hello Jade,
I tried replicating the test case locally and the popups seemed to work fine. Could you tell me what version of iOS you have on your device?
Thanks
JadeFreeman
I'm on iOS 9.1.  However, I'm pretty sure it has something to do with the may service.  In the web map, when I click on the 'Configure Popup' link, the popup configuration dialog is never shown and in the chrome dev tools console I get a variety of error messages (see below).
The only thing I can think of is the service was published with the preserve layer id's option turned on in Arcmap.  It's a 10.3.1 server hosting the service.  Like I said, I have other services that work just fine.
Thanks!
TypeError: Cannot read property 'name' of undefined(…) "TypeError: Cannot read property 'name' of undefined
    at Object.arcgisonline.map.main.getLayerTitle (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:11536:85)
    at b.declare._init (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:1291:435)
    at b.declare.startup (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:1259:36)
    at https://<<server name>>/portal/home/10.3.1/js/arcgisonline/base.js:820:46
    at Object.h.forEach (https://<<server name>>/portal/home/10.3.1/js/jsapi/dojo/dojo.js:235:285)
    at d.startup (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/base.js:819:471)
    at Object.g.around.advice (https://<<server name>>/portal/home/10.3.1/js/jsapi/dojo/dojo.js:250:237)
    at h.(anonymous function).g [as startup] (https://<<server name>>/portal/home/10.3.1/js/jsapi/dojo/dojo.js:250:39)
    at n (https://<<server name>>/portal/home/10.3.1/js/jsapi/dojo/dojo.js:112:92)
    at d.startup (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/base.js:695:282)"n @ dojo.js:formatted:5859(anonymous function) @ dojo.js:formatted:5883h.filter @ dojo.js:formatted:6503k @ dojo.js:formatted:5882
dojo.js:formatted:5859 TypeError: Cannot read property 'destroy' of undefined(…) "TypeError: Cannot read property 'destroy' of undefined
    at b.declare.destroy (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:1257:205)
    at b.declare.showStack_PopupStack (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:9222:220)
    at b.declare.showStack (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:9209:30)
    at e (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:1219:92)
    at https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:1223:70
    at c (https://<<server name>>/portal/home/10.3.1/js/jsapi/dojo/dojo.js:83:221)
    at A.then.then [as then] (https://<<server name>>/portal/home/10.3.1/js/jsapi/dojo/dojo.js:85:301)
    at Object.arcgisonline.map.leftPanel.openLeftPopupPanel (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:1222:490)
    at b.declare.configurePopup (https://<<server name>>/portal/home/10.3.1/js/arcgisonline/arcgisonline.js:12161:479)
    at null.<anonymous> (https://<<server name>>/portal/home/10.3.1/js/jsapi/dojo/dojo.js:183:241)"n @ dojo.js:formatted:5859(anonymous function) @ dojo.js:formatted:5883h.filter @ dojo.js:formatted:6503k @ dojo.js:formatted:5882
JadeFreeman
If I add one the sublayer I'm trying to create a popup on as a feature layer to my map, I cannot configure popups on that layer until I remove the dynamic map layer, save the map and then reload the map.  I can then configure popups on it.
There must be something about the service that neither portal nor Explorer likes.
MitchJohnson
If you are still facing this issue, make sure you have the "SHAPE" field visible on your layers in your map service prior to publishing.
