Links not working in Explorer
3896
08-15-2014 01:47 PM
LarryFox
I'm trying to access PDFs stored locally on a machine using Arcgis explorer but can't seem to get them working.  I'm using a shapefile created in ArcMap.  The data comes from a join between a table and a polygon feature class.  The links work in ArcMap but do not work in Explorer.  I've tried the following:
C:\GIS Files\TEST\FTP Voyager Sync folder\Complex.pdf
file:///C:\GIS Files\TEST\FTP Voyager Sync folder\Complex.pdf
file://///C:\GIS Files\TEST\FTP Voyager Sync folder\Complex.pdf
Any help would be appreciated!
Larry Fox
Tags (1)
JakeSkinner
Esri Esteemed Contributor
JakeSkinner
Hi Larry,
The below KB article may be of some help:
40989 - Configure hyperlinks for use in ArcGIS Explorer for Desktop
LarryFox
Did the trick.  Thank you!
