I'm experimenting with Explorer (beta) on an Android device, and would like to take a map offline. I've created an MMPK in ArcGIS Pro, how do I side load it on my android device?
1866
10-30-2017 02:23 AM
peninahGacheru
Tags (1)
DanPatterson_Retired
the reference to side load is here http://doc.arcgis.com/en/explorer/ipad/help/make-maps.htm
under Share your map, if this applies... no Android mention in Beta
AlexanderNohe1
Honored Contributor
You can sideload it by plugging your Android device into your computer and then in the Android File Transfer tool, loading it into /ArcGIS/mmpks/ folder.
bobchristensen1
Hi, I have been able to successfully side-load to iOS via itunes but a colleague of mine has had trouble finding the right folder using windows to access android. Any tips? He says he can't find the arcgis folder at all.
b
MarkBockenhauer
Bob,
I would expect it to be there...
I just USB cable connect to windows and open the folder.
Mark
