Explorer on iPhone crashes
799
03-30-2018 11:46 PM
EdBradford
On Saturday, March 31, 2018 I created a KML file using Google Earth. I translated it to a GPX file using GPSBable.
I then created a map on ArcGis online for use on my mobile device. The GPX file loaded OK, but any time
I zoomed or dragged the map, Explorer (ArcGis Mobile Explorer for iPhone) crashed. The map I made is public and can be seen here: https://arcg.is/1DyjSK  or by searching for  "Llano-Brenham-H&TC" -- it's a map of all the railroad lines, spurs and sidings between Llano and Brenham, Texas on the Houston and Texas Central Railroad (H&TC).
The KML files is 259,159 bytes in size and the GPX files is 433,863 bytes.
The GPX file is attached.
Ed Bradford
[email protected]
MarkBockenhauer
Ed,
Can repro the crash.   I was able to publish the feature collection as a hosted feature service,  and the feature service does work.
Mark
HeatherMcCracken
Hi Ed Bradford‌,
I was able to reproduce this issue as well - thanks for sharing the GPX file.  It appears that you are running into a known issue we have in handling large feature collections.
What mbockenhauer-esristaff suggests above will workaround this issue. Publishing a hosted feature layer from the collection.
Is this something that is a manageable workaround for you?
Heather
