Explorer app (Android) - untrusted host
5713
11
01-06-2019 12:50 PM
JohnPlunkett
Hi team
I am working with a customer and sometimes we get this message appearing when using the app. However we can't click the trust button. - The message goes away if we close the app and reopen it. - however every now and then the message appears again.
Have others had this message appear?
We do get this when on Wifi or Cellular
by Anonymous User
Not applicable
Hey John Plunkett‌ and Brian Wilson‌,
This issue will be addressed in the next release of the Android version of Explorer.
Joel
BrianWilson3
I get this message as well.  I'm using a galaxy s9+, portal 10.6.1 using iwa.  Im on 18.1.0.  Using the new explorer and collector via iOS shows no errors.  The app appears to be fine and shows data then after a minute or so I get prompted in a never ended loop of untrusted hosts. SSL shopper shows the certs are good for both portal and ags.
by Anonymous User
Not applicable
Joel
BrianWilson3
When will this version be release?
by Anonymous User
Not applicable
Brian Wilson‌ we're looking to have 19.1.0 Beta's available for iOS, Android, and Windows available around User Conference (July). Our final releases would follow shortly after that. This release will include numerous bug fixes (including the issue above) as well as supporting additional offline workflows.
GrahameRoss1
I have a user starting his field season and needs to access our spatial data... no hope for a fix for at least 2+ more months? Is this related to the security updates requiring us to install TLS patch 1.2 regarding esri's data services?
app works on my personal Iphone- no way to push out a fix to android quicker???
BrianWilson3
This issue was around prior to the tls push. I agree this needs to be patch asap.
Sent from my Verizon, Samsung Galaxy smartphone
JeffreyROLAND
It's now October, when is this update supposed to happen?
GrahameRoss1
Agreed! Still using a workaround in the field. would like Explorer back ASAP...
jprasadpwa
Hey, we are getting the untrusted issue in the ArcGIS explorer app. it is continuing for all layers means if the web map having 20 layers 20 times is getting. is there any solution to avoid this
