Selection not working?
2083
02-21-2012 10:42 AM
BrettBlankner
Several of our map services have recently stopped returning any results if you try to select features on their maps.  Is there a setting to turn this off and on or something?  Or is there a common culprit that causes this that we can fix?
Brett
NadeemShaukat
I have the same issue with "Select Features" tool in Arc Explorer Online. After picking the tool and making a rectangle around features returns nothing.
Are there any requirements to have this tool function properly? Could someone from ESRI respond?
EricLacoursiere
Hi there,
I'm having the same problem here.
Could we have some help?
Eric Lacoursiere
MiguelMartinez
I'm experiencing the same issue as well.  I click the "Select Features" button and draw a box around data that was imported in a .csv file but it doesn't select any of the data.  What am I doing wrong or is this a systemwide esri problem?  Please let me know.
