Paste from a table function has stopped working
1793
06-25-2012 01:21 AM
JasonSawle
Hello
I use the 'Paste from a table' function to import data a lot, but I have noticed that over the last few days this function has stopped working. The process moves through the sequence of events to import the data but when you click on Import the data does not appear on the map, but a new layer is created in the TOC.
I have tried different web browsers and different PC's to eliminate any local reason for the problem with this function. The same data can still be mapped by navigating to the file, so there is not a problem with the data.
Has anyone else noticed this problem?
Regards
Jason Sawle
Esri UK
