Obtaining imported data from Explorer Online
2273
03-04-2013 06:48 AM
NicholasLarson
Is there anyway in which I can "recover" data from a map created using Arcgis Explorer online? I know there are some handy scripts for converting Exlorer Online notes in to shapefiles. I am hoping to obtain a shapefile that I loaded in to a map document, but am not sure if I am able to convert or save the shapefil in question in any way. I can't locate the shapefile and would like to do some analysis, and make some new maps using the particulart shapefile, the map I created seems to be the only place I can seem to aquire the file in question, so it would be very helpful if I can get this in to a shapefile that could then be edited in Arcmap.
Thanks!
RupertEssinger
Esri Alum
Open your web map in ArcGIS 10.1 via the File > ArcGIS Online command in ArcMap and all the layers in the web map will appear in the resulting ArcMap document. You can then export them to other formats.
