Failed to import shapefile - Failed to compare two elements in the array.
3234
07-14-2011 08:18 AM
by Anonymous User
Not applicable
Original User: BruceLang
Some shapefiles (ZIPped) import fine while others trigger an error.  The shapefiles were created using the same procedure.  (created ArcEditor 9.3.1)
  • Dist_Airport.zip - Imports without error
  • Dist_Fire.zip - Does not import, triggers an error
What is the meaning of this error?  "Failed to compare two elements in the array"
Thank you.
ShellyGill2
Hi Bruce
I think you're running in to some kind of a limit on vertex numbers or numbers of parts on an imported polygon here. I tried splitting your shapefile up, and it's just feature number 9 that's showing the problem, and splitting that feature into two separate polygons meant that both imported OK. I'll refer this one for more investigation.
On the subject of the error messages, we're aware that the error messages are currently not very informative in many cases, and are working to improve this in a future release. I'll update this thread when I find out more on the issue, and make sure the help is updated with more information too.
by Anonymous User
Not applicable
Thank you Shelly.
BTW - The ability to import shapefile data into ArcGIS.com is TREMENDOUSLY SUPER!! :cool:
