case sensitive searches
3036
01-10-2012 05:57 AM
PaulLohr
I've discovered that the search/query function on ArcGIS Explorer Online is case sensitive. Any way to make this case insensitive?
Thanks for your help,
Paul Lohr
Paul Lohr
Lohr Geospatial Services, Inc.
deleted-user-TpPHp85BOy9L
Have you been able to find a solution to this problem?  I am having the same problem.
Found the solution to this problem finally!  The layer I was trying to query was in a file geodatabase on the server - I moved the feature class over from the file geodatabase to our SDE and the queries are no longer case-sensitive in Arc Explorer Online.
JackZHANG
Just tried your way, didn't work for me.....
