Measure --> Add to Map switches x,y to y,x
1650
06-05-2014 07:05 AM
ElizabethKelly
I'm measuring in UTM and would like the labels in "Contents" to automatically read Easting, Northing. Is there a non-manual solution?
Description: When I mark a point on the map with the Measure tool, the Measure window displays X: 450000 Y: 600000. When I select the point and click "Add to Map," the numbers are switched and the point is labeled 600000, 450000.
