XML Serialization
1431
11-01-2011 12:01 PM
BrianLocke
XML
Was this done in a specific way just for AGX or does it follow a standard such as GML ???? could you create a GML/GEORSS standard and use that to pass to a worker thread and still serialize also allowing for spatial data to be passed back and forth between Terminal Node Connectors and also SQL Server 2008 spatial DB's ??
BrianLocke
So looking into things a bit more I see that there is the method .GetXMLSchema, so would this allow you to assign a XSD file to it and then when the .ToXMLString() method is called it will then put it out in that schema and appropriate elements??/
