XML serialization Passing list(of Note) back to RunWorkerCompleted UI
1348
10-20-2011 03:21 PM
BrianLocke
yeah I am trying to figure out how I would post a list(of Note) back to the UI and add them, any ideas here is what I have
Public Class FlghtPthBtn
  Inherits ESRI.ArcGISExplorer.Application.Button
    'declarations
    Private disp As MapDisplay = ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay
    Private CurrentMap As Map = ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay.Map
    Private Pline As Geometry
    Private RepString As StringBuilder
    Private PtList As List(Of String)
    Private WithEvents _bgWorker_FlightPath As ESRI.ArcGISExplorer.Threading.BackgroundWorker
    Public Overrides Sub OnClick()
        _bgWorker_FlightPath = New ESRI.ArcGISExplorer.Threading.BackgroundWorker
        AddHandler _bgWorker_FlightPath.DoWork, AddressOf _bgWorker_FlightPath_DoWork
        AddHandler _bgWorker_FlightPath.RunWorkerCompleted, AddressOf _bgWorker_FlightPath_RunWorkCompleted
        Pline = disp.TrackPolyline(Color.Lime, 4)
        If (Not _bgWorker_FlightPath.IsBusy) Then
            _bgWorker_FlightPath.RunWorkerAsync(Pline.ToXmlString())
        End If
    End Sub
    Private Sub _bgWorker_FlightPath_DoWork(ByVal sender As System.Object, ByVal e As ESRI.ArcGISExplorer.Threading.DoWorkEventArgs)
        Dim PL As ESRI.ArcGISExplorer.Geometry.Polyline = ESRI.ArcGISExplorer.Geometry.Polyline.CreateFromXmlString(CStr(e.Argument))
        Dim PLLat As String
        Dim PLLong As String
        Dim Brng As String
        Dim PrWindow As New PrgrssFrm
        Dim PtNote As String
        PtList = New List(Of String)()
        PrWindow.Show()
        RepString = New StringBuilder()
        For I = 0 To PL.PointCount - 1
            PrWindow.PrgrssBrLbl.Text = "Doing " + (I + 1).ToString + " of " + PL.PointCount.ToString
            PrWindow.FlghtPthPrgrssBr.Value = (I / PL.PointCount) * 100
            PLLat = PL.GetPoint(I).GetLatitude.ToString("###.0000")
            PLLong = PL.GetPoint(I).GetLongitude.ToString("###.0000")
            If I + 1 <= PL.PointCount - 1 Then
                Brng = BearingDetail(PL.GetPoint(I), PL.GetPoint(I + 1))
            Else
                Brng = "NA"
            End If
            RepString.Append((I + 1).ToString + " Lat: " + PLLat + " Long:" + PLLong + " Heading: " + Brng + " ")
            '' PtNote = New Geometry(ESRI.ArcGISExplorer.Geometry.Point(PL.GetPoint(I))).ToXmlString
            PtList.Add(PtNote)
            e.Result = PtList
        Next I
        PrWindow.Close()
    End Sub
    Private Sub _bgWorker_FlightPath_RunWorkCompleted(ByVal sender As System.Object, ByVal e As ESRI.ArcGISExplorer.Threading.RunWorkerCompletedEventArgs)
        ''  Dim results As Graphic = New Geometry(ESRI.ArcGISExplorer.Geometry.Point.CreateFromXmlString(CStr(e.Result)))
        MsgBox(RepString.ToString)
        disp.Map.ChildItems.Add(Results)
    End Sub
    Public Function BearingDetail(ByVal Pt As ESRI.ArcGISExplorer.Geometry.Point, ByVal HeadPt As ESRI.ArcGISExplorer.Geometry.Point)
        'Ported Over from SpotFires BearingdistanceDetail- Created by Mike Shuft and Steve O'Brien ported By Brian Locke
        'Dim brg As String
        Dim changex As Double
        Dim changey As Double
        'Dim length As Double
        ' Dim angle As Double
        Dim quadrant As String = Nothing
        changex = Pt.X - HeadPt.GetLongitude
        changey = Pt.Y - HeadPt.GetLatitude
        'Determine the Direction
        If changex = 0 And changey = 0 Then quadrant = "You must pick two different points!"
        If changex = 0 Then
            If changey < 0 Then
                quadrant = "S"
            ElseIf changey > 0 Then
                quadrant = "N"
            End If
        End If
        If changey = 0 Then
            If changex < 0 Then
                quadrant = "W"
            ElseIf changex > 0 Then
                quadrant = "E"
            End If
        End If
        If changey > 0 Then
            If changex < 0 Then
                quadrant = "NW"
                quadrant = "NE"
            End If
        End If
        If changey < 0 Then
            If changex < 0 Then
                quadrant = "SW"
                quadrant = "SE"
            End If
        End If
        Dim Dlon As Double = ESRI.ArcGISExplorer.Geometry.Unit.Angular.Degrees.Convert((HeadPt.GetLongitude - Pt.X), Unit.Angular.Radians)
        Dim PtY As Double
        Dim HeadPty As Double
        PtY = ESRI.ArcGISExplorer.Geometry.Unit.Angular.Degrees.Convert(Pt.Y, Unit.Angular.Radians)
        HeadPty = ESRI.ArcGISExplorer.Geometry.Unit.Angular.Degrees.Convert(HeadPt.GetLatitude, Unit.Angular.Radians)
        Dim y As Double = Sin(Dlon) * Cos(HeadPty)
        Dim x As Double = Cos(PtY) * Sin(HeadPty) - Sin(PtY) * Cos(HeadPty) * Cos(Dlon)
        Dim brg As Double = Atan2(y, x)
        Dim bearing As String = quadrant + " " + ((ESRI.ArcGISExplorer.Geometry.Unit.Angular.Radians.Convert(brg, Unit.Angular.Degrees) + 180) Mod 360).ToString("###.00°")
        Return bearing   'Returns the bearing
    End Function
