WPF Overview Map - Error: The ArcGISExplorer SDK is not correctly installed
2584
07-08-2010 12:43 AM
RasmusBjerner
I found the WPF Overview Map at http://arcscripts.esri.com/details.asp?dbid=16871 very interesting, so I downloaded it, downloaded and installed ArcGIS Explorer and ArcGIS Explorer SDK.
I opened the Visual Studio solution and tried to compile the solution, but I get the following error:
The ArcGISExplorer SDK is not correctly installed - 'ESRI.ArcGISExplorer.targets' not found (ArcGIS_E3SDK='C:\Program Files\Explorer\DeveloperKit').
What do I do wrong?
Best Regards
Bjerner
ShellyGill2
This issue has been seen before, although we do not have a fix, a reboot normally solves this problem (it seems that Visual Studio does not gain the environment variable correctly when the SDK is installed). See:
http://resources.arcgis.com/content/kbase?fa=articleShow&d=37176
Let me know if that doesnt solve the problem for you.
