Why do subscribed thread question message links not find linked discussion?
560
02-28-2013 03:06 PM
GraemeBrowning
I wanted to suggest to the author of the message below that it may be related to an earlier posting by Mark Bockenhauer at http://forums.arcgis.com/threads/61091-ArcGIS-Explorer-2500-discussion?p=212205
However, when I visit the thread via the link provided, or try to find the message using ctrl-f and strings from it, it seems no longer to be there.  Was it perhaps deleted?  I raise this because my perception is that such "missing messages" seem to be becoming more common.
Dear graeme,
mauicountywwr has just replied to a thread you have subscribed to entitled - ArcGIS Explorer 2500 discussion - in the ArcGIS Explorer Desktop forum of Forums.
This thread is located at:
'>http://forums.arcgis.com/threads/61091-ArcGIS-Explorer-2500-discussion?goto=newpost
Here is the message that has just been posted:
Anyone else been noticing erratic behavior with only the Bing Basemaps in AGX 2500?  All other basemaps work fine.  The Bing Basemaps seem to work fine when I first open AGX but if it sits for a while, then I try to scroll around the streaming is really bad, and sometimes takes minutes to complete in one spot. very strange.  Then when I change to a basemap other than Bing and they all work fine even after sitting for a while.  1750 did not have this issue and I did check another staff computer running 1750 on the same network with no issues.  This tells me it's probably not a Bing/internet side issue and is probably on my side.  I've cleard the E3 cash several times to see if it was a hiccup but has not remedied the problem.
Anyone else having this issue?  Or have a fix?
Thanks.
There may also be other replies, but you will not receive any more notifications until you visit the forum again.
All the best,
Forums
