Craig, we've checked add-in over here, and nobody had the issue logging in. Log into your account on twitter.com, check that you didn't revoke ArcGIS Explorer from your trusted application, and just make sure your credentials work on twitter as well. Hope it helps!
I am using add-in successfully on 1750:
[ATTACH=CONFIG]10017[/ATTACH]
