Sum attribute?
1336
05-16-2011 09:17 PM
AustinKleinberg
I just installed ArcGIS Explorer, and I have a question. Is it possible to find all the values of a certain attribute? For example, I am using the National Hydrography Dataset (NHD), and queried for a certain stream. Now I want all the values for length in kilometers for that stream, so I can add them up and find the total length of the stream. I cannot figure out how to do it. Thoughts? Thanks in advance.
DarrylDempsey
Austin,
Here's an Addin we use which calculates statistics (count, min, max, sum(numbers), mean(numbers)) for columns in any map item with a table (including query results). Some obvious improvements would be:
- a more appropriate icon (Sigma?)
- using Julian Day Numbers to be able to calculate more than just min and max for date-time fields
- a frequency distribution graph as in ArcMap
The C# code is available if you want.
AustinKleinberg
That's great! Thanks, both of you!
