Setup default map along with Data and add-in
889
12-18-2011 08:22 AM
ManojrajTeli
is it possible to make a setup executable(exe) package containing Arcgis Explorer along with my configuration, add-in and nmf file along with data(Geaodatabase,shapefile on which nmf ) into single executable file.Thank you in advance.
SarahGreenlaw
that's a brilliant question! I'd be interested in the same thing!
it sounds like you are quite experienced with ArcGIS Explorer - do you happen to know the answer to this?
http://forums.arcgis.com/threads/46211-Users-can-t-save-any-changes-when-an-application-configuratio...
