Select Notes by location
1171
02-08-2011 10:40 AM
GraydonShevchenko
I'm wondering if there's a method like Select By Location on this application.  I'm trying to programmatically select point notes that are within a polygon feature class.  I can't find anything in the SDK methods and properties.  Perhaps someone has any ideas?
AndreiIvanov
Graydon,
you can do the opposite: select features from the feature class that are within the note's geometry. You would need to work with Table class (Search method) of the feature layer.
