Searching data with ArcGIS Explorer
3475
10-29-2014 01:06 PM
RobNanz
I have ArcGIS Explorer and use an NMF file to then view data from DBF, SHP and other files.  The end result map shows me property lines from my county and when I click on a property I get details about it such as the owner, address, etc.  I am wanting to search this data but am unable to determine how.  How can I search and quickly locate data on this map.  Thanks.
MarkBockenhauer
The ribbon tabs and buttons are driven by context.  You need to click on your feature layer in the table of contents.  The commands applicable to that layer type will then display.
MarkBockenhauer
For feature layers you can use the Query Builder in ArcGIS Explorer Desktop.
mark
RobNanz
My version does not have a Tools tab.  ?  I only have Home and Display tabs.
MarkBockenhauer
RobNanz
Got it.  Thanks, it is working now.
