SDE Server Side Requirements
814
04-28-2010 08:18 AM
RobertHeitzman
I can connect to our geodatabase SQL server OK from ArcCatalog but when I use the same Server/Service(sde:sqlserver:<serverName>)/Database/Authentication parameters from ArcExplorer 1200 I get a "failed to connect" message.
I have the ArcGISExplorerDataAccessDownload pack installed although I don't see any difference from a macine with or without the pack installed.
Is there something that needs to be done on the server side to allow access from ArcExplorer?
What else may be wrong?
