ArcGIS Explorer COM Interface
3404
04-08-2010 06:35 AM
thomaslepkowski
I would like to launch AGX and load a KML or shapefile or anything supported from within another process using COM.  For a java example, this is easy using Google Earth and com4j.
Here are the "api" docs: http://earth.google.com/comapi
My question is, where are the equivalent docs for AGX and where is this type of functionality discussed?
ShellyGill2
If you want to programmatically customize ArcGIS Explorer, you can download the free SDK from:
http://resources.esri.com/arcgisexplorer/1200/index.cfm?fa=download
An online version of the SDK documentation can be found here:
http://resources.esri.com/help/1200/arcgisexplorer/conceptualhelp/index.html
and API reference here:
http://resources.esri.com/help/1200/arcgisexplorer/componenthelp/index.html#/_/000300000426000000/
I dont know any examples of doing exactly what you're after, but if you want to do something in ArcGIS Explorer at startup, I would suggest you take a look at making an Extension, and go from there:
http://resources.esri.com/help/1200/arcgisexplorer/conceptualhelp/index.html#/creating_a_custom_exte...
thomaslepkowski
Thanks sgill,
What I'm after is launching AGX from another program.  That's all.  Your reply addresses something else, but I appreciate your comments.
KirkKuykendall
Why do you want to use COM?
Seems like an AGX extension could be written that does interprocess communication via WCF or sockets.
http://msdn.microsoft.com/en-us/library/fx6588te.aspx
http://resources.esri.com/help/1200/arcgisexplorer/conceptualhelp/index.html#/application_namespace_...
AnthonyCatalano
I agree COM is so (AAAHhhhhh) scary. The SDK has code for .net but java and .net are both object orientated languages. Why not create a wrapper class in java and kick off a .net solution through java?? At least there you can have some encapsulation.
