In ArcMap 10.1, I open a shapefile, symbolized it, set the display field, set the html popup to display as a table of the visible fields. I selected some of the fields as visible. I didn???t set any label.
Then I created a layer file and opened it in ArcExplorer Desktop 2500, but when I selected a polygon the popup window header had a fieldname corresponding to one of the fields that is not the one selected in the display tab, nor in the popup window, not in the visible fields.
I also tried creating a Layer package, but the problems remains.
Does anyone knows how to solve it?
Julia
