Point feature not displaying with Bing Maps layer basemap
799
08-14-2012 10:40 AM
KyleProsen
I loaded a point shapefile into Desktop Explorer, and the points display when the Bings Hybrid base layer map is inactive. However, when the Bing maps base layer is active, the point shapefile disappears below it. When I rearrange the order of shapefiles in the table of contents, the point shapefile still does not show. Is there some other way to help this shapefile display? Is there a particular reason it may not be showing? Is this a bug to be worked out at a later date?
Thanks
