Open tables arcgis explorer
4390
11-12-2010 02:56 AM
alexgaritaonandia
I am new in Arcgis Explorer. Does anyone now if I can open a table of a shapefile or geodatabase directly in arcgis explorer desktop or do I have to implement with some add-ins or arcgis explorer sdk. Thanks in advance.
MichaelBranscomb
Esri Frequent Contributor
This isn't out-of-the-box functionality - but the good news is that it is relatively straightforward to add. There's a sample in the SDK (http://help.arcgis.com/en/arcgisexplorer/1500/sdk/conceptualhelp/index.html#//00020000003z000000) which demonstrates this. You can use the SDK with Visual Studio Express if you don't already have a development environment.
If you weren't looking for this level of involvement just yet - i could build the sample and post on ArcGIS.com for you.
There are also some other great Add-ins available on ArcGIS.com - try http://www.arcgis.com/home/search.html?q=ArcGIs%20Explorer&t=content&focus=tools and look for Query Plus. Select-o-Matic might also be useful to you.
Regards
Mike
alexgaritaonandia
Regards
Mike
Thank you Mike,
I will be pleased if you can post it in arcgis.com. Otherwise I will see if the SDK is not to difficult (I don't have Visual Studio) or wait until the next version of arcgis explorer.
MichaelBranscomb
alexgaritaonandia
Try http://www.arcgis.com/home/item.html?id=669ac5da0855466e8a6d6ca4d287ede0
Regards
Mike
Thanks alot.
This is what I needed. It's perfect.
