.nmc where did the elevation data go?
1704
6
11-18-2010 04:52 AM
derekmotsch
In the past, I have used Arc GIS Explorer to create ground profiles.
I use the terrain profile add in.
Save the profile as its own .NMC, change the .NMC to an xml and open in excel.
I have an excel spread sheet that calculates the cumulative horizontal and vertical distance for export to other programs.
Today, I open the nmc as xml and notice that elevations are no longer included?
Is there a way to get the elevations back? I had a nice quick work flow creating ground profiles for use outside of explorer.
Thanks for any help you might be able to provide.
MichaelBranscomb
Esri Frequent Contributor
When you say "in the past" - which version of ArcGIS Explorer were you using? 500? 900? 1200?
Cheers
Mike
derekmotsch
I am fairly confident that this was still working in 1200, I created the spread sheet that makes calculations with the elevation data in December 2009, whichever version it was then. I think I used it back in the spring, but probably not since the latest release. If that helps.
I believe I still have 1200 or earlier installed at home and I am going to try that.
To clarify my work flow, I saved the terrain profile as a .nmc, changed the file extension to .xml, opened in excel as a table, there was a column for X,Y, and Z, now when I do that the column for Z is missing.
Why would that information no longer be included?
MichaelBranscomb
This looks like it might be a bug. I'm currently confirming whether this is the case.
Regards
Mike
derekmotsch
Thanks for looking into this.
I took some screen shots of what I used to get and what I get now
Notice how one table has a Z column and the other doesn't
Thanks again
I currently get this
I used to get this
derekmotsch
I checked build 1200 at home. The .nmc file for the terrain profile contains the the Z column and associated elevation data.
MichaelBranscomb
This was a deliberate change at version 1500 - the accuracy of the Z values, particularly at a global scale, varied too much and we therefore modified the overall behaviour and introduced a more accurate way to obtain the Z values in the API: http://help.arcgis.com/en/arcgisexplorer/1500/sdk/componenthelp/index.html#/GetSurfaceElevationGeome.... This means you'll need to write an Add-in using the SDK - but the benefit is that you'll have a more streamlined workflow (i.e. you should be able to automate the Note/NMC > XML > Excel process to simply produce a spreadsheet of the values you require).
Regards
Mike
