ArcGIS Explorer 1500 & direct connect to 9.2 sde géodatabase
816
11-05-2010 06:44 AM
ErwanCaradec
can i use ArcGIS Explorer 1500 with ArcGIS Explorer Data Access Expansion Pack to make a direct connect to a 9.2 ArcSDE géodatabase (on sql server) ?
I currently have this error Message "Failed to connect to <USERNAME>."
I've checked the connection informations was the same as used in ArcMAP with "GDB Direct connect" :
Geodatabase type: ArcSDE Geodatabse
Server: Myserver name
Service: sde:sqlserver:MyServerAdress
Database: MydatabseName
using database authentification Username/Password
Regards,
Erwan
DaraBurlo
Esri Alum
Do you have the SQL Server Native Client installed? If you don't, try installing that from Microsoft's download site.
Dara
