Missing data in the events layer attribute table
1776
01-12-2011 08:23 AM
dansmall
After adding an excel file and checking the attribut table (all fields are there), then adding XY data I start to have problems.  The points all show up on the map, when I use the identify button all the information is there for that point. The problem is that in the event layers attribut table no data is there, but all the field headings are there.  Because of this I cannot make these data points into shapefiles. I have added tables, added XY data and converted to shapefiles many times and this is the first time I have run into this problem.
Dan
dansmall
I wasn't able to figure out the problem when trying to add an excel file, but I saved each excel sheet as a text file and added them, then added XY data and exported to a Shapefile and everything worked.
Dan
