Map Service Projection?
3419
12-03-2010 07:56 AM
JerryGarcia
For AGX 3D view, what is the recommended projection for map services?  WGS84, Web Mercator, ?
MarkBockenhauer
Both of these coordinate systems have equal performance in 3D if they are fully cached map services.
JerryGarcia
Our map services are not cached because we need to be able to toggle individual layers on and off in the globe.  In this case, what is the recommended projection for the best performance?  Apparently, you cannot turn on and off individual layers with multilayer cache map services in ArcGIS Explorer?  Also, they may no longer be recommended?  Thanks!
