Lock - password protect my map
4291
11-12-2010 08:32 PM
AchilleasDrosos
Can i password protect my map in arcgis explorer?
JamesStewart
I haven't seen anything about passwords.  I'm 'locking' down my maps using using the configuration manager if that helps...
AchilleasDrosos
How? can you explain...?
MichaelBranscomb
Esri Frequent Contributor
You can tailor the user experience and add/remove functionality via "Application Configurations" - see http://webhelp.esri.com/arcgisexplorer/1500//en/appconfigs.htm for more info.
If you want to password protect the map you could use regular windows file security or alternatively consider creating an "Extension Add-in" which you would then deploy as part of an Application Configuration. This Extension Add-in gives you the chance to run some code as the application is starting - in which you could validate the logged in user against an Access Control List, or hook into your enterprise security approach perhaps. Or you could display a prompt asking the user for their credentials then again do the validation against your list/user database. See http://help.arcgis.com/en/arcgisexplorer/1500/sdk/componenthelp/index.html#/d/0003000003tv000000.htm for more information.
Regards
Mike
AchilleasDrosos
thanks i ll try and come back with questions and results...
