Legend Help!
3746
02-27-2014 09:47 AM
ELTerrell
I' working on my legend and I have 12 items.  Under properties > items > style I know I can change the layout of the legend.  However, they seem to only offer a vertical list of all 12 items.  Is there a way to stack them in 2 columns (6x6) instead of a list of 12?  Thanks in advance!
BondHarper
For an existing legend, under Legend Properties, Items you can select your breakpoint (your 7th layer) and click 'Place Item in new column". The rest of the layers will be in the 2nd column. Also, when you are first setting up your legend there is an option at the bottom to set the number of columns.
BondHarper
ELTerrell
That worked, thanks!
