adding data
4004
03-11-2014 07:58 AM
ELTerrell
Gota question,
I have a map of 195 precincts in a county.  I want to add to the attribute table a spread sheet with 1 value per precinct.  Is this a join?  How can I get it to add to the attribute table?  I tried the join data but the "ok" is never able to be clicked.  Advise?
TimWitt
Correct, as long as those are unique numbers.
TimWitt
Edwin,
to be able to join one thing to the other they both need to have a field with a unique identifier, which the joint will be based on. Do you have such a field on both attribute tables?
Tim
ELTerrell
So the first column in the table is the FID....numbers 0 - 194.  I should have that on the spreadsheet I attach?
TimWitt
ELTerrell
That worked, thanks!
