Is it possible to remove or turn the visibility off for tools on a ribbon at run-time
1252
12-21-2010 06:17 PM
JerryGarcia
Is it possible to remove or turn the visibility off for tools on a ribbon at run-time?
ShellyGill2
Hi Jerry,
I'm afraid not, there's no changing of the ribbon possible at run time. The contents of the ribbon tabs are all worked out when the application loads, for example any new Add-Ins are found and loaded into the Add-Ins tab at that point. I dont even know any ways that you could work around this behind the scenes I'm afraid.
JerryGarcia
Hi Jerry,
Since the nmf is XML, we are building this on-the-fly and launching it.
