Clear Layer Cache
1193
12-21-2010 03:56 AM
BrianLeroux
I am looking to clear the cache on the selected layer. I am able to get it to work on either a Service Layer or a Feature layer. What I am trying to do now is have it detect which type the layer is so that it can refresh using the corrct code. I am stuck on trying to detect the layer type. Any thoughts? TIA.
Public Overrides Sub OnClick()
        Dim slayer As ServiceLayer
        Dim flayer As FeatureLayer
        If ESRI.ArcGISExplorer.Application.Application.SelectedItems(0).GetType = ServiceLayer Then
            slayer = TryCast(ESRI.ArcGISExplorer.Application.Application.SelectedItems(0), ServiceLayer)
            slayer.ClearCache()
            System.Windows.Forms.MessageBox.Show("The cache for the selected layer has been cleared!", "CACHE", Windows.Forms.MessageBoxButtons.OK)
        ElseIf ESRI.ArcGISExplorer.Application.Application.SelectedItems(0).GetType = FeatureLayer Then
            flayer = TryCast(ESRI.ArcGISExplorer.Application.Application.SelectedItems(0), FeatureLayer)
            flayer.ClearCache()
        Else : System.Windows.Forms.MessageBox.Show("The cache for the selected layer could not be cleared due to incorrect layer type!", "CACHE", Windows.Forms.MessageBoxButtons.OK)
        End If
    End Sub
AndreiIvanov
Brian,
ServiceLayer, FeatureLayer, RasterLayer and etc are all inherit from Layer class. So the easiest way to clear the cache is to cast selected mapitem to Layer, and if it is valid call layer.ClearCache();
BrianLeroux
aivanov -
That simplifies things a bit. For some reason I thought i tried that. Guess not. Thank you..
        Dim xlayer As Layer = TryCast(ESRI.ArcGISExplorer.Application.Application.SelectedItems(0), Layer)
        xlayer.ClearCache()
        System.Windows.Forms.MessageBox.Show("The cache for the selected layer has been cleared!", "Layer Cache", Windows.Forms.MessageBoxButtons.OK)
    End Sub
