Invalid field name length in dbf?
5086
06-22-2010 09:44 AM
DarrenLacina
I am having a problem adding several shapefiles in Explorer due to an apparent issue with their dbf files. Here is the error message I received for one of the files I tried to load:
> Jun 22, 2010 12:54:04 PM: com.esri.mo.file.shp.ShapefileFolder$c_
com.esri.mo.file.shp.InvalidFieldNameException: The field name () has an invalid length in (M:\GPS_Projects\FranklinCarmichael\Export\SHP_exports\0517-0604_combined3_QC\Park.dbf)
I have checked all field names in the problem dbf files and all satisfy the 10 character max limitation for the shapefile format. Is there something else I should be looking for?
MikeRudden
The exception you are gettting does indeed imply that there is an invalid field. Unfortunately there is not enough information here to diagnose the problem or to establish whether it is a bug. If possible, please can you post the dbf file and I'd be happy to give it a try for you.
Mike Rudden
ESRI
ErosSy
i encountered same problem.. could you try my shp and dbf file.
unable to view using ArcExplorer then I check the log.
i think the log is insufficient.
> 2010/10/01 16:28:06:    com.esri.mo.file.shp.ShapefileFolder$c_
com.esri.mo.file.shp.InvalidFieldNameException: The field name () has an invalid length in (C:\shapetest\Test.dbf)
[ATTACH]2858[/ATTACH]
zip file contents: Test.shp Test.shx Test.dbf
ErosSy
I am using
ArcExplorer (TM) - Java Edition
Version 9.3.1
Build 2095.1230
ErosSy
I was able to view by changing my fieldname
fieldname: Log Index -> LogIndex
space in fieldname is a limitation?
Then, I also tried to change my fieldname to non-english. It displays garbage..
e.g. English -> Japanese
fieldname: LogIndex -> �?��?��?��?��??�??�?��?�
Please try it as soon as you read this post.
Thanks
AndreiIvanov
ArcExplorer has been superseded by ArcGIS  Explorer.  I recommend you to try it out. It is a free GIS viewer.
