Darryl,
I took a look at this, and found that I could not reproduce the problem if I set the map coordinate system to RD_New.. similar to what Andrei reported. However, If I set a transformation (Amersfoort to wgs 1984), I do see the photograph placed, away from where I clicked.
To explain the difference between your two computers, it may be a difference of the map and specifically whether a transformation is being used or not.
Mark
