Import kml
3467
6
09-09-2010 08:09 AM
Roberto_JWeigand
Hello
I have a problem.
when I try to import some file "kml", the application closes
Others, they work perfectly
Send a bad files
MichaelLakey
The zip you attached seems to be invailid.  Says this "does not appear to be a valid archive".
Mike
dcopple
Tried to look at the Zip file, didn't open.  My guess is there is something within the KML file that is not letting it open.  Too many points, large file?  Does it open in GE?
AndreiIvanov
Crashed in 1200, thought it works like a charm in 1500. Are you up-to-date with new ArcGIS Explorer release?!
AndreiIvanov
The kml file has animation, and it somehow causing problem with 1200 build. Though, it's been fixed in 1500.
Roberto_JWeigand
No, I have a bigger file and it does not give me problems
I have installed the new version and neither it works. It turns to close the program.
Also, with the version 1500 I do not see others that if they were working in 1200.
Roberto_JWeigand
Pardon
I have unistall all quite, included complements, have begun again and reinstalled the version 1500
The problem is solved.
I give for the thread closed.
Thanks to all for everything
