Identify Multipatch AGX
2385
6
10-19-2011 05:29 AM
JurajMalega
hi
i have a problem with identify multipatches in agx 1750.
Any ideas how to show some attributes of multipatch afterClick???
I know the way through the Pop-up window, but i would like to create my own add-in, like button which i clik and after that i clik on multipatch and get informations from multipatch...I wanna use that informations in other function...
thank!
best regards
AndreiIvanov
Juraj,
it looks that identify for multipatch is broken in 1750. Thank you letting us know. We will fix it for the next release.
JurajMalega
Andriy,
thanks for your response...
i realy need to identify or get informations about multipatches....please can you help with some steps thrue this?
i post another thread on forum yesterday about Popup windows...but no response till now...
is some way how to disable Popup in SDK, and allow it from my Button Addin?
i don´t wanna use Popup like left clik in AGX, but i need my own Button, which i push and after that i can call Popup window...
any ideas please??
thanks in advance,
Juraj
AndreiIvanov
Juraj,
if you need identify multipatch uninstall 1750 and install 1700. 1750 was a minor release, so no problem sticking with 1700 for some time.
Popup windows: what you are trying to do goes beyond capabilities of ArcGIS Explorer SDK, but take a look at this post:
http://forums.arcgis.com/threads/21294-how-to-create-identify-tool.......?highlight=identify
You "could" set layer's popup state, though it is a hidden property, thus not supported by ESRI, and it could be broken in the future releases. You'd need to call:
featureLayer.PopupProperties.PopupType = PopupLayerType.None
setting it back: PopupLayerType.PopupFields or PopupLayerType.PopupHyperlink
Hope it helps!
JurajMalega
hello andryi,
thanks for your advice, it helps very well.
but i have another problem. I need to my own Popup design, like i can change it when i use LayerPackage with XSL syntax. I would like to call PopupLayerType.PopupFields, but with XSL design. Is it possible to call programatically XSL from hard drive or tkae it directly to the code?? i need it because in xml i wanna write javascript which saves some attribute on hard drive (in txt), and after that i use that attribute in DockWindow and finally i "identify" Multipatch.
thanks in advance,
Juraj
JurajMalega
hi...
i have one more question...
is some way how to take out buttons in popup window and use my own buttons there??
see attached file...
thank you very much
JurajMalega
Juraj,
Hope it helps!
hi andriy
i tried to uninstal 1750 and take back 1700...
and identify doesnt work..!
any ideas??
thanks
