Hyperlinking in ArcExplorer?
4755
11-11-2014 04:47 AM
AdrieBorman1
Hi Everyone
I would like to be able to click on a feature on the map and have the desired fields for that feature "popup."
Then, one of the fields that pops up would have the link to the folder containing documents for that feature and you could just click on that link if you want to see the documents (hyperlink). Any thoughts or suggestions will be
appreciated.  Many thanks.  Adrie
Tags (1)
DanPatterson_Retired
You need ArcMap
AdrieBorman1
Hi Dan
Thank you for replying.
This is what I've done, but the link is not working.
See attached image, with ref to DOC_LINK field
Regards
MarkBockenhauer
Using a shapefile in ArcGIS Explorer Desktop your attribute would need to look like this for a local file.
file:///C:/Users/Public/Documents/note.txt
and you would have to specify it the layer properties.
The popup would then show the file in the popup window.
I presume that the OP is asking for more than that simple functionality.
