Original User: julia.galindo
Mark, I followed your instructions, unfortunately, it did not work, I created an attribute called �??Name�?� as suggested. I filled it with the value �??Datos�?� just to have something in it. Then I created a layer package with 13 layers ( all the shapefiles referencing the layer have the same attribute). When I click on a polygon, the popup window does not recognize the attribute Name, it pick any other text attribute. There is only a couple of layer that used the attribute, but the name of the attribute not the value. See an example
