how to create identify tool.......
3985
01-16-2011 11:52 PM
srinivasreddy
Actually i tried to make a tool like identity in explorer, i achieved upto certain extent, but here i write the code under button_click event, means before going to click on the map user has too click on the button then only it is working.
But i need the way in ARcMap(like once user selects the tool(here button) until and unless he selects another tool it works for identify the features)....So here i need to write the code map_click event. but i haven't found such event on explorer desktop. if anybody having solutions give me some ideas.....
thank you.....
RuthSantoro
I'm very interesting in this as well, could you give us some hints to develop the Identify tool?
It's the first time I use ArcGIS Explorer and I would appreciate any help.
Thank you in advance.
Ruth
AndreiIvanov
Identify tool already exist within application. What are you trying to achieve rewriting it yourself?
You can imitate "tool" behavior with ExplorerTimer and BeginTrackPoint, something like that:
    public class Button : ESRI.ArcGISExplorer.Application.Button
        ExplorerTimer _timer;
        public override void OnClick()
            _timer = new ExplorerTimer();
            _timer.Interval = 200;
            _timer.Tick += new EventHandler(timer_Tick);
            ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay.BeginTrackPoint(new TrackDelegate(TrackPoint), DisplayEffect.Flash);
        void timer_Tick(object sender, EventArgs e)
            _timer.Stop();
        /// <summary>
        /// Tracking callback for point measuring.
        /// </summary>
        private void TrackPoint(TrackingInfo trackingInfo)
            if (trackingInfo.Status == TrackStatus.Completed)
                //write your identify code here
                _timer.Start();
srinivasreddy
Thank you.. very much for ur reply mr.Andriy Ivanov..............
BingZhu
We need to customize the popup window when identify a feature. How to access the popup class from the Addin (dockable window) so the attribute data in the Addin can be displayed in customized popup window?
Thanks!
SarahGreenlaw
Hello!
see this link on the Identify tool already in ArcGIS Explorer - maybe it will suit your needs?
http://forums.arcgis.com/threads/42661-Exporting-layer-package-to-display-in-ArcExplorer
Sarah
